View Poll Results: TrailBoss 250 help
help
100.00%
help
0%
Voters: 1. You may not vote on this poll
TrailBoss 250 help
Old Sep 18, 2012 | 12:41 PM
jmoney1991's Avatar
Today im riding and after about 45 minutes of riding my TrailBoss seemed like it may have overheated and died its done this a few times and once i let it sit it will fire right up? Is this normal since its a 2 stroke?
Old Sep 18, 2012 | 12:57 PM
Nope,not normal!! Check compression. If around 110 or lower then it could be time for a fresh top end. If it runs awhile and dies then piston and ring to cylinder clearance can widen,loosing even more compression and die.When it cools down some will crank back up until warm again. Plus the crank seals you mentioned earlier may need to be replaced also. OPT
Old Sep 18, 2012 | 01:08 PM
jmoney1991's Avatar
Ill do a compression test as soon as can, its running strong its jus seems when i full throttle it for awhile it bogs out and dies hopefully i dont have to do a rebuild that sounds expensive and thats something ive never done is a rebuild.
Old Sep 18, 2012 | 01:22 PM
jmoney1991's Avatar
if you go on youtube.com my username is 92591money the second video is it bogging out after riding and it was in a little backyard, i ride all over my neighborhood and if i dont crank full throttle it wont die on me but when i crank full throttle for like 10 minutes it dies, ill just have to wait till tomorrow to get the carb kit and then see what happens im just new to atvs and want it to run like a champ but like i said im new to atvs
Old Sep 18, 2012 | 01:28 PM
  #15
jmoney1991's Avatar
Also if you watch the video i paid 700$ tell me if its worth that, all the plastic is not broke and seat is not ripped it was garage kept and was taking care of pretty good just another question i have...sorry
Old Sep 18, 2012 | 03:25 PM
  #16
Have you rebuilt the carb yet as you mentioned?? Could be all that's wrong,could be just flooding out,but best to do a compression check. Plus again gas in the recoil area is because it got past the crank seals which could be another part of the problem. All things have to work together for an engine to run properly.You have to have the correct amount of air, correct amount of fuel, good compression(top end compression,plus bottom end compression (crank seals) and spark. OPT
Old Sep 18, 2012 | 03:32 PM
  #17
jmoney1991's Avatar
ill have the carb kit tomorrow i ordered it three days ago so i should have it tomorrow ill get on here again after i rebuild the carb and ride it and let you know if it worked or not, after i do the rebuild ill find some crank seals which im hoping is a easy fix and replace those i might have more questions on replacing the crank seals.
im glad your helping me man i joined this site hoping you would help cause ive read other post where you helped people and you knew what you were talkn about.
Thanks
Old Sep 18, 2012 | 03:45 PM
  #18
Keep your chin up! Post back after you get the carb fixed as to how it's doing....... OPT
Old Sep 18, 2012 | 03:49 PM
  #19
jmoney1991's Avatar
Will do man im so happy i got the four wheeler and you to help ill post wednesday or thursday on the carb rebuild and how it went ive been tryn to find a friend who has a compression tester so ill be in touch. Thanks again i really appreciate your help you deserve a trophy lol
Old Sep 18, 2012 | 08:48 PM
  #20
jmoney1991's Avatar
On the crankcase and cylinder diagram on the website you gave me, what parts number is the crank seals u were talkn about you said there was two seals needing replace is the one seal #26 on the diagram? I want to be sure also could you find a link where they sell the seals i need that would work on my atv please? Thanks
