OPT..Heeelp.Predator 90 is having a problem again
Old Oct 2, 2012 | 01:53 PM
monstertruck76's Avatar
Default OPT..Heeelp.Predator 90 is having a problem again
I bought new 12v 4 amp battery for starting Preda..30seconds after connecting battery stator trowed white smoke in the air..Fuse didnt blow but batterys plus connector melted!!??..battery connectors were right and batt was brand new.....Whatta h****l now happened
Old Oct 2, 2012 | 02:25 PM
If you're positive the connections to the battery were right then sounds like you have a job now tracing down wires starting with the stator into the wiring harness for any shorts. Plus was it running before you installed the new battery? Was the stator an oem or a generic after market? Could be the problem?Wiring harness is about 80 bucks if it comes down to that.If I remember correctly didn't you just replace a cdi module that was burnt? Could have been the stator going out that caused this? Just thinking out loud again.. OPT
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
