97 Xplorer 500 Lack of Performance
Diaphragm shouldn't turn around the slide easily. If the diaphragm is distorted could cause this and problems your having? Diaphragm and slide comes as an assembly and isn't cheap! About $86 new. OPT
*****SOLVED*****
Put in the new diaphragm/slide assembly and the low end throttle response was a bit better, but still wasn't much improvement.
Was about to give up, then looked at the slide needle again. The E-clip was on the lowest position. I moved it to the middle, and it ran different instantly. It revved much faster and higher, and now it spins the tires!
I wasn't expecting it to be quite as fast as it is now! I don't really miss my YFZ any more...
Sep 30, 2015 01:37 AM
