Need help on 1996 Polaris sportsman 400 lights
Old Dec 21, 2012 | 01:01 PM
SmileforanOmega's Avatar
Exclamation Need help on 1996 Polaris sportsman 400 lights
Hi, I was wondering if anyone would know were to stat looking when the lights on a 1996 Polaris sportsman 400 quite working. I was driving it a couple of days ago in the snow and the low lights suddenly went out when I heard a pop, the high lights on it had quite working a few days before. would anyone know where to start looking for a broken part? Thanks!
Old Dec 21, 2012 | 06:13 PM
Welcome! First off if you have a bad or weak battery(have it load tested if you're not sure) you can pop lights from the regulator/ rectifier trying to charge a shorted out battery (that won't take the voltage) and the voltage takes the path of least resistance which is always the bulbs.Check that the charging voltage at the battery is between 13.5 to 14.5 volts while at a high idle. Plus check all the wiring connectors on the regulator located between the front bumper and radiator. They have a bad habit of pulling out and not charging which can drain a battery down. Plus a regulator can sometimes over charge (16-18 volts normally) which can dry a battery up and cause problems. These are things you might need to check out along with the simple stuff like making sure the battery connections are tight. OPT
Old Dec 22, 2012 | 05:22 PM
Thanks for the help old polaris tech, I tried checking what you said and it looks like I might have a short that's draining the battery. I'll see what I find after I check the wiring.
Old Jan 22, 2013 | 09:53 AM
The positive line attaching to the battery was partly broken. I replaced the line and the bulbs, Now it's working fine. Thank's for all the help!
Old Jan 22, 2013 | 11:18 AM
Make sure you're charging 14-14.5 volts back to the battery while running. OPT
whitty
67
Feb 24, 2021 02:52 PM
neilbedwell
Nov 10, 2018 11:02 AM
yellowpolaris
Jun 21, 2015 11:13 AM
May 27, 2015 11:15 AM
PolarisPower500
May 17, 2015 02:28 PM
