06 sportsman 500 HO efi
Old Jan 19, 2013 | 08:05 PM
skull246's Avatar
Default 06 sportsman 500 HO efi
was looking at the bike today and i seem to have alot of lean inwards on my front tires do i have a problem?
Old Jan 19, 2013 | 08:06 PM
skull246's Avatar
oh should mention its the top that lean in towards each other
Old Jan 19, 2013 | 09:40 PM
Usually just something that's normal as they get a little older.Plus there's no adjustment for camber. As springs,suspension begin to wear the tires kinda lean out at the bottom,in at the top. Have had guys install stiffer springs,etc to try to correct this.Some looked better,some didn't. You can slowly jack the front end up,taking the load off and you'll see the tires straighten up a little.Plush push up and down on the front end. If the front end bounces up quickly and isn't stiff,could be time to replace worn strut cartridges. OPT
Old Jan 20, 2013 | 08:16 AM
skull246's Avatar
how hard is it to change them ,and roughly how much to fix ?
Old Jan 20, 2013 | 08:25 AM
Look at this link from a recent post. Plus heavy duty front springs are offered from Polaris,etc if this is what you want.Plus you can always just try spring spacers first. http://forums.atvconnection.com/pola...rer-400-a.html
http://forums.atvconnection.com/pola...-pictures.html
OPT
Old Jan 20, 2013 | 09:52 AM
skull246's Avatar
i think the spacer idea for now will work , and go from there
Old Jan 20, 2013 | 10:06 AM
I figured you'd go for the spacer as it's the easiest to do first. If this doesn't help you can always replace the cartridges/springs if needed. Plus something as simple as this might help.http://www.ebay.com/itm/Polaris-ATV-...-/180718176320
OPT
Old Jan 20, 2013 | 05:34 PM
skull246's Avatar
the only thing wrong with those is ,they would cost me 31 bucks with shipping i think i could make sum nice one a little cheaper
Old Feb 3, 2013 | 11:41 PM
Rickeyparker's Avatar
There used to be a sticky for the front spacers, Stendori posted it at one time.
Old Feb 4, 2013 | 08:04 AM
Think this is the one you're thinking of.http://forums.atvconnection.com/pola...-pictures.html
OPT
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
