how can i load my sportsman?!?!?!?
so i took the clutch cover and belt off my quad so i could wash the oil off. but i need to take it to the heated car wash to wash and dry it so it doesn't freeze. my quad won't start because its so cold and i started winching it on the ramps into my truck, but then the winch crapped out! so the front tires are on the ramps and me and my brother can't push it up at all. i don't know who to call, how can i get my quad up the ramps without driving it?
Do you have a ****** block for your winch? Does the winch have a free spool mode? I had to use a small chain between the truck bed tie-downs. Connected the ****** block to it, ran my cable from the winch to the block than back out of the truck bed. Than use a chain to hook to another truck/car to pull it into the truck. Could also work without the ****** block. Just have to work slow
Yea, that's close......put the first chain across the box on the tie downs. Than use the cable from your winch to put around that chain. Than run your cable out the back of the truck. You may or may not need the other chain to attach to a pulling vehicle.
As another member mentioned the come-a-longs would work also.
Njrider1230
07-29-2023 05:16 AM
bzdok1234
30
02-23-2016 01:55 PM
