2004 Sportsman 500HO rattle from the front
Old Jan 22, 2013 | 07:20 PM
sbishop664's Avatar
Default 2004 Sportsman 500HO rattle from the front
Hi, i'm trying to figure out where this ratlle is coming from. it doesn't do it at idle or high speed...when taking off or driving 5mph there is a loud plastic or rack rattle. i searched the forum and find some info but no real fix. Any guess or fix where it is coming from?
Thanks
Sbishop
Old Jan 22, 2013 | 07:46 PM
Cummins Driver's Avatar
Its not coming from the clutch is it? I know when the clutch components start to get worn they can knock and clatter pretty good.
Old Jan 22, 2013 | 08:11 PM
sbishop664's Avatar
No i'm pretty sure its not mechanical, its more a rattle then a knock or clatter...more annoying then anything else...especially if you are taking off slowly.
Sbishop
Old Jan 22, 2013 | 08:36 PM
Things that you can check are the front panel(under the front rack),make sure it's in place properly,plus under the front panel are two small bolts on either side that holds the front cab in place. Could be rattling there if a bolt is loose or missing.If you have a winch see if you can eliminate it as the noise source. Plus check the strut mounts at the top to make sure the top and bottom strut pivots haven't cracked and fallen out. Can make noise there. Item #19 and 24. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
If all else fail strap someone light on the front that has good ears.That's where a wife or girl friend comes in handy OPT
Old Jan 22, 2013 | 08:42 PM
sbishop664's Avatar
OPT, i was thinking of taking parts off until the noise stopped...i'll remove the front rack first and work my way along....it might be a day or 2...kinda chilly here at -22celcius without the wind....brrrr!
Old Jan 22, 2013 | 08:57 PM
That's close to -8 degrees fahrenheit It was a balmy 70 degrees here Sunday. Don't blame you one bit for waiting. OPT
Old Jan 22, 2013 | 10:20 PM
user493's Avatar
Moto Psycho
Front racks have been known to rattle sometimes.
bzdok1234
30
Feb 23, 2016 01:55 PM
coldnorthpol
Jul 14, 2015 11:22 PM
Shifts
Jul 3, 2015 07:59 AM
Mphillips
Jul 2, 2015 07:20 PM
bikedad3
Jun 29, 2015 08:58 AM
