stator testing
Old Feb 13, 2013 | 10:01 PM
giver gas's Avatar
Default stator testing
does anybody know the correct way to test a stator on a 06 sportsman 800 it has a 6 prong plug with jumper wires from one side to the other?
Old Feb 14, 2013 | 07:41 AM
No spark? Charging problem? Have you checked for any codes?
Old Feb 16, 2013 | 02:03 PM
giver gas's Avatar
i'm having issues with spark and thought it tested good before and now it seems to test bad but i just want to make sure i'm testing the stator correct.
Old Feb 16, 2013 | 06:07 PM
First thing pop the top off the throttle housing and check that the contact points are open(not touching) on the ETC switch after you adjust slack at the thumb throttle to about 1/8" play. If this doesn't help on spark then check the crank position sensor harness connection along the wiring itself for any bare wire that could be shorting out to the engine. These are the first two trouble shooting tests along with some obvious ones like making sure the battery is good,connections are tight,no damaged plug wires. I don't have the 2006 manual,but have a Polaris 2005 700/800 pdf manual which should be the same. So far it doesn't show a good test on the stator harness wiring that I've been able to find,but no stator wire (except only a brown ground wire) should zero out to ground!All should show open to ground. I'll look again,but the manual isn't too clear on some tests.
Joe454
Nov 20, 2020 01:19 PM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
johnny1982
Sep 13, 2015 07:41 PM
