sparkless sportsman
Old Feb 25, 2013 | 07:44 PM
kylesfarm's Avatar
Default sparkless sportsman
i have a '97 sportsman 500 that doesnt have spark. i tried disconnecting the kill switch and that didnt help. i tested the ignition coil and i get a resistance reading but theres no power coming out of the wire from the cdi box.
i tested the wires from the stator and pulser since they feed into the cdi box. i get a resistance reading from the stator but nothing from the pulser. also when i turn the engine over i get a power reading coming from the stator but nothing from the pulser.
is my pulser bad or am i not testing it right? if it is bad i noticed theres no way to disconnect it. do the new ones come with a big long wire that i have to feed up to the cdi or do i have to solder the new and old wires together?
Old Feb 25, 2013 | 08:05 PM
The pulser coil should show 97 ohms resistance(+ or - 20%) between the white and white/red wires. If it doesn't you can pull the recoil assembly and see if one of the soldered wires may have come loose.If the pulser connections are ok ,you can try this place about purchasing just the pulser coil.Also the exciter(main stator) readings should be 446 ohms between the Black/Red to Green OR Black/Red to Red (whichever colors you have) If both checks are bad then a complete stator assembly may be needed. Ricky Stator - Manufacturer of ATV & Dirt Bike Stators, Electrical Components, Lighting Systems and Suspension Products
Looks like the new pulser(pick up coils) have the wiring now.http://www.rickystator.com/catalog/p...oil-p-328.html
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
