HD Spring upgrade??
Best to have an air ratchet or air gun. Remove the tie rod ends at the strut,remove the one bolt holding the brake line strap.Loosen the top strut nut and remove it along with the pivot ball,metal and rubber washer.Lower the strut down on a 4x4 block of wood and gently swing the strut out to where you can remove the lower pivot ball and impact the strut retainer nut off.The retainer plate will pop up when you do. Pull the old spring off,replace with the new one. Pull the strut shaft up and wrap a piece of towel around the shaft about 6 inches from the top and clamp with a pair of vice grips. Turn the vice grips and the spring will coil around it compressing it enough to install the retainer plate and nut. While still holding the vice grips,impact the nut tight. Reinstall the bottom pivot ball and swing back into position and install the top pivot,rubber washer ,metal washer and nut. You can let the vice grips turn to hit the frame support as you tighten the top nut. Gets a lot easier and quicker the more times you do it
When swapping to HD springs I borrowed a set of spring compressors from my local auto parts, Autozone, orielly's, advance, whoever you got that does that. Jacked the quad up about 2" off the ground, compress the spring, remove top nut and washer, swing strut out far enough to pull spring up and off, decompress stock spring. Reverse steps to install new springs. The spring compressors are the best way to go IMO. super easy and had the job done in about an hour from start to finish including removing the front box.
When I did my fronts, I didn't even use compressors, not saying its not another way to do it..I was told you don't need them for the fronts but you will for the rears if you wanna do them..I was able to get the fronts in by dropping the strut just enough to sneak spring in but not too much where you might pull axle out too far..But the compressors would be a good idea also if you want..
John
John
