Sportsman will not start, please help!
what opt means is
use a DC voltage test light black lead to ground , TIP to red/white wire contact at the starter switch
push starter switch , if voltage is passing through , test light will illuminate
if test light illuminates , you have a broken red/white wire leading to the starter solenoid
Looking at the schematic,yes the Red/black and Yellow should have 12 volts on the switch harness. The Yellow wire goes straight to the fuse block 20 amp fuse. If the White/red wire to the solenoid shows continuity,then best guess is that the ignition switch is faulty,not powering up the solenoid. Faulty ignition switch was #5 on 13 item flow chart test check.
Last edited by old polaris tech; 07-17-2013 at 03:54 PM. Reason: Had wiring wrong! Should be White/red wire to solenoid
#15
#16
#17
#18
"IF" you have power going into the ignition switch as you said earlier and you said the power wire(red/white) from the solenoid back had continuity,then this might still be your problem. You can run a jumper wire by passing this wire and test to see if this helps. If not,then it's like you said you have a problem elsewhere other than the switch, the ignition switch harness and the solenoid red/white power wire..
