preasure washing ?????
Old Mar 31, 2001 | 07:09 PM
o2b4unc's Avatar
I run 6 machines and live for mud. Power washing is the only way to go. Never had a problem, machines look great. After they dry, squirt just about every inch with some wd40.
Keeps their value higher...
Old Mar 31, 2001 | 11:06 PM
sabot's Avatar
Hey almar your right. Before wheelers had liquid cooled engeines you couldn't hurt much.Now with the radiators you have to be careful.
Old Apr 1, 2001 | 12:06 AM
Madman72's Avatar
Yes it's just fine, but be careful, as the rest of the guys said, Be careful around the seals and intakes. Don't spray to heavily on the decals either, It can sometimes take the paint right off(I know from personal experience)
Old Apr 1, 2001 | 05:46 PM
ecorman1's Avatar
The manufacturers are covering their butts! They know we're going to pressure wash and they don't want to be responsible for faulty items like electrical or mechanical due to water leakage. When I get to the upper parts, speedometer, shifters, air horn, I stand back so as not to get a lot of impact on those parts. Also, the spark plug wiring and foot shifter. Everything else gets a good going over, especially the plastic, top and bottom.
After washing, I spray with Liquid Wrench inside all the wheel wells, over the shafts, seals and joints. This helps make dirt easy to remove the next time. You don't have to wait for the bike to dry before spraying. Liqud Wrench (WD40) removes water.
I use wax on the metal where the seat mounts. You might notice, the seat takes the paint off the frame. Rub a stick of wax over the area, keeps it from rusting.
Chuck
panicmanic
Sep 20, 2015 05:54 PM
bigred20653
Sep 19, 2015 02:11 PM
Ean
Aug 20, 2015 07:13 AM
WilliamBos
Jul 25, 2015 02:41 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
