Polaris Hawkeye Blowing Fuses
Old Mar 20, 2014 | 09:14 PM
  #21
Yooper265's Avatar
Originally Posted by Lolumad273
Just unplugged that switch after finding that the Red and black wires that come out of the ignition switch had 0 ohms to ground. After unplugging the switches on the left handlebar, I found R/W 40 is 0 ohms to ground.
Between 34 Green and 40 R/W there is no resistance, and both are shorted to ground. I've traced both wires back to the fuse plugs, and can't find anything, and they're still shorted. Gotta look at it again later.
34 green goes to the headlights so you're probably reading through the lamp filaments to ground- normal , I'd check into the ground on the r/w wire . It goes to the #1 r/w spice , there's six wires there , isolate them and and see which one is grounded , good luck , you're getting close !
Old Mar 27, 2014 | 01:28 PM
  #22
Lolumad273's Avatar
Indeed I was reading through the lamp filaments, for some reason I assumed they'd have a higher amount of resistance. Anyway, I unplugged the CDI and now the fuse doesn't get blown! The display even comes on. I unplugged the first connector, where 11 R/W goes. I'll have to see if there's a short beyond that point or if the CDI is faulty.
Old Apr 17, 2014 | 10:24 PM
  #23
nullmemory419's Avatar
Hello, Umad. I see you're from Upstate New York. I'm from upstate NY Aswell.
I have a 2006 Polaris Hawkeye Aswell i picked up from Johnstown,NY. I'm wondering if it's the same one because my fuse keeps blowing as soon as i turn the key. LOL. Did you ever end up figuring it out?
Old Apr 17, 2014 | 10:31 PM
  #24
Lolumad273's Avatar
I believe it's my ignition control module. I'm on vacation until the weekend, when I get back I can take a photo of the plug I unplugged to test the module for you.
Old Sep 24, 2014 | 06:27 PM
  #25
Lolumad273's Avatar
Well I forgot to message back, but indeed it was my ignition control module. Bought an aftermarket one that doesn't work either so I'm starting a new thread about that.
Captjay
Jul 23, 2015 12:33 PM
Reactant
Jul 16, 2015 10:29 PM
Unzzy66
Jul 11, 2015 10:01 PM
