2000 Polaris Trail Blazer 250 battery wont charge
Hi I have a 2000 Polaris Trail Blazer 250 that well not start un less u unhook the black wire coming off the Voltage Regulator Rectifier I have replaced the Voltage Regulator Rectifier the key switch and the on and off kill switch on the Handel bars And steel did not help ! My starter wont work ether u have to pull start it . And all so the battery wont charge could it be the starter or the cdi box ??? Oh and I all so but a new Solenoid on it to try to get the starter working but didn't help
![Confused](https://atvconnection.com/forums/images/smilies/confused.gif)
Okay... possible you could have a shorted out regulator causing the problems,but eliminate a stator problem first. Test yellow wires coming from the stator with a meter. No yellow should zero out to ground. If the stator charge wires show ok,here's a place for regulators.I'd call as as to the correct one available as your model oem part # is 4060208 and not listed. Polaris ATV Rectifier Regulator If all else fails,one on ebay a little cheaper than most places.http://www.ebay.com/itm/LR39-1-Regulator-Rectifier-Polaris-Blazer-Sport-Scrambler-Xpoler-4060208-New-/251505299773?pt=Motorcycles_Parts_Accessories&hash=item3a8ee2513d&vxp=mtr
Okay... possible you could have a shorted out regulator causing the problems,but eliminate a stator problem first. Test yellow wires coming from the stator with a meter. No yellow should zero out to ground. If the stator charge wires show ok,here's a place for regulators.I'd call as as to the correct one available as your model oem part # is 4060208 and not listed. Polaris ATV Rectifier Regulator If all else fails,one on ebay a little cheaper than most places.LR39 1 Regulator Rectifier Polaris Blazer Sport Scrambler Xpoler 4060208 New | eBay
I know this is an old thread but when you say zero out to ground what does that mean exactly? AC or DC test? Also I assume the red probe goes in the yellow/yellow brown output from the the stator, where does the black probe go? To any ground like the frame ground or the stator ground?
Peeps
03-24-2000 12:27 AM
