No 4wd in reverse
Old Apr 4, 2001 | 07:51 PM
BORNtoRIDE's Avatar
Sometimes when I shift my SP500 into reverse the override is automatically kicked in. The reverse light doesn't come on. The 4wd won't work either. Sometimes when I shift it into reverse it is normal. Could it not be shifting all the way into reverse? Any help would be greatly appreciated!
Old Apr 4, 2001 | 08:51 PM
ScrambledKiwi's Avatar
Take it to a dealer. Sounds like somthing is loose either electronic or mechanial.
Old Apr 4, 2001 | 09:39 PM
KINGofthehill's Avatar
Sounds like your problem is right in front of u... P-O-L-A-R-I-S!!!
Old Apr 5, 2001 | 07:06 AM
Loyal's Avatar
It happened to my 96X400. It is the switch that runs from the gear shift to the circuit board. I let the dealer fix that one. part was about $75 canadian.
Old Apr 5, 2001 | 07:47 AM
floodrunner's Avatar
The Polaris service manual (not the bogus owners manual) will tell you that is a symptom of improper shift linkage adjustment, and that’s what it sounds like to me. The way to find out is to adjust your shift linkage to the proper specs, or have a competent mechanic do it. If you still have the problem after that I’d say you have a weak / intermittent reverse switch.
Old Apr 5, 2001 | 08:31 AM
POLECAT's Avatar
KING OF WHAT,JUST ANSWER THE QUESTION.JUST BECAUSE YOU ARE P-O-L-A-R-I-S ENVY,DONT TAKE IT OUT ON HIM.
Old Apr 5, 2001 | 11:03 AM
Farmr123's Avatar
Most likely it isn't quite kicking all the way into reverse. Make sure the shifter linkage is adjusted properly. If that seems all OK, it could be the reverse/neutral sensor on the tranny housing.
Old Apr 5, 2001 | 12:15 PM
AKScrambler's Avatar
You might try getting into your wiring harness and bypassing the override switch to test it. It's easy to do and easy to remove(the bypass you use). Just look at a wiring diagram. This will help isolate the problem. HTH
lonerider856
Oct 13, 2023 03:45 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
poutlaw525
Sep 9, 2015 03:19 AM
