polaris carb
Old May 26, 2015 | 04:09 PM
Yes. Pull the gas to line to the carb,pull the vacuum line from the other side of the carb and use a mity vac to pull a vacuum. If the hoses are in good shape,fuel valve is in the on or reserve position and verified not stopped up and you can 't get gas to flow, then it's a fuel pump problem even though you said you replaced one from another machine.If you do have fuel,then sounds like you need to check into the carb again. If you have to tear into the carb again,install a carb kit. No need of going into a carb more than once! Plenty of them on ebay for your model 500.Sportsman 500 carb kits | eBay
neilbedwell
Nov 10, 2018 11:02 AM
Ipmcelroy
Technical and How-To Articles
48
Nov 21, 2015 08:02 AM
Evan d
Jul 7, 2015 02:36 PM
gfl0224
Jun 27, 2015 06:52 PM
DOAinNY
Jun 11, 2015 10:34 PM
