Ground wire question
Old Oct 18, 2015 | 10:53 AM
  #21
Originally Posted by hkc3
IT WORKS!!, although all the time, I'll have to check out the switch when I get a chance. I got this a few years ago to ride with the grandkids and we had some fun. But the oldest is driving and the other is in sports big time so we didn't ride much this year. I figured if I could get the 4wd working I could plow my driveway with it and get some use out of it. Thank you very much.
Ain't electrical problems fun..
Old Oct 19, 2015 | 06:42 PM
  #22
hkc3's Avatar
They aren't bad when you have someone as considerate as you to help. I checked the switch, it's ok. I jacked it up to check the 4whl. and when I shut of the switch the front tires were still turning [with force] I just figured the front shafts were at bad angle and the hubs were in a little bit of bind. Or maybe I need to go in reverse a little to unlock them. I took it for a short ride and I couldn't really tell the difference in the ride w/without 4whl lock. Are they all that way.?
Old Oct 19, 2015 | 06:50 PM
  #23
Up in the air when you kick the awd button off you should be able to stop the wheels from turning with your foot. They will sometimes keep turning because there's no load or force on them to make them quit. If one wheel keeps locked in,you may just have to ride it a little more and see if it works it self out or you may have one armature plate magnetized. If that's the case it can lock in in two wheel drive mode also and you may have to stop,back up to unlock it.Worst case you may need to replace the armature plates.
Old Oct 19, 2015 | 08:28 PM
  #24
hkc3's Avatar
Okay, thanks again.
panicmanic
Sep 20, 2015 05:54 PM
79hugger
Aug 30, 2015 02:21 PM
frostphase
Aug 19, 2015 07:11 PM
oldschool64
Aug 12, 2015 07:13 AM
Schneider
Jul 24, 2015 05:05 PM
