Voltage regulator?
Old Feb 18, 2016 | 10:02 AM
Originally Posted by Kazjag500
Is the voltage regulator required for ignition? Like if I have a blown Voltage Regulator would it cause no spark? And would disconnect and reconnecting the battery cause the stator to go as well?
It can cause problems yes.. Modules such as the regulator can go first along with cdis,bulbs,etc. You can generally check all the stator yellows also by checking resistance between each other. Yellows should show some resistance between each other with no yellows shorting to ground. Plus in some cases you can visually check for bulges,burnt areas,plus sometimes you can smell modules and tell if they're burnt.Again the manual is the best on tests and checking..
Old Feb 18, 2016 | 10:04 AM
Kazjag500's Avatar
Ride it like you stole it
Okay, but if I were to unplug the the voltage regulator would it make any difference? Like just to test if it is that or not? And how would I test the voltage regulator and CDI? Thanks
Old Feb 18, 2016 | 10:07 AM
NO good cdi test. manuals say to replace with a known good one.. That's why you try to eliminate everything else first,then replace a cdi if all other tests are positive..Just look at this generalized regulator test.
You can disconnect the regulator and see if it cranks. If it doesn't,problems are elsewhere.
Old Feb 18, 2016 | 10:21 AM
Kazjag500's Avatar
Is there any way to bypass the CDI? I saw a website that explains how to bypass the CDI do you think this would actually work? Just for a second or two to determine if the CDI is really the problem causing the ATV to not start?
I have attached a link of the resource where I got this information from,
Thanks
How do you bypass a CDI box?
Old Feb 18, 2016 | 10:24 AM
  #15
Thanks
Better to just get the cheap 5 buck manual rather than take a chance on further damage if the stator isn't already damaged in doing these by pass tricks...
Old Feb 18, 2016 | 10:42 AM
  #16
Kazjag500's Avatar
Thanks
And to add on to that. The bike has been through lots of salt and water. And also, I removed the rear fender to fix the rear differential bracket and when I was pulling the battery wires back into the hole to attach the to the battery, I was using quite some force pulling on the wires, and also. there has been previous issues with the bike randomly stalling and not being able to start for like 20 minutes. It has only happened like once or twice, but when this happened I thought it was just the same issue, but it has been almost 3 weeks now since this has happened and now the bike is getting in the way and we need it fixed.
Old Feb 18, 2016 | 03:09 PM
  #17
Then sounds like you really need that cheap 5 buck manual..
superunknown23
Feb 23, 2016 12:39 PM
Ipmcelroy
Feb 17, 2016 05:47 PM
Greasemonkey2067
Feb 16, 2016 12:28 PM
MapleNeil
Feb 15, 2016 05:22 PM
Redzbeard
Feb 14, 2016 09:37 AM
