02 Sportsman 700 Carb Questions - Jets & Float Height
I'd cross my fingers for ya if I could.. You can pull the fuel line from the carb and crank the engine over. If the fuel pump is ok you'd have steady or pulsing stream of fuel.If you have that,carb is eliminated also,then sounds like that Demon Ducati ignition problem. If it is,the cheapest 2202602 kit I've found is from Parts Pit Stop @ 493.56. https://www.partspitstop.com/oempart...2/kit-ignition Unless you want to go the cheaper RM Stator route.
UPDATE: I'm going to start another thread since my issues have changed from the original questions I had.
THanks for all of the help with these original questions related to the carb.
NEW THREAD IS HERE: https://atvconnection.com/forums/pol...ml#post3385386
