new to me 2006 sportsman 500 efi having issues
Old Feb 26, 2018 | 10:05 AM
Around the pins to cut down on corrosion. Rubber surround keeps a lot of moisture out but not all. Same for the connectors on the left control switch,cdi,coil and anything else that you might think would get water or moisture in. Same for the recoil cover as that's another place for water entry.Good rtv sealant for it. Plus you can use rtv on the rope handle to the nipple. Easy to break loose if you need it. The factory really didn't have water proofing in mind when they built these machines.
Old Feb 26, 2018 | 10:40 AM
uncle al's Avatar
STAND FOR THE FLAG
thanks again, started the quad today, but will still put some grease on things.
Dusty011
Sep 2, 2012 10:36 AM
fortworthmudrider
Aug 15, 2008 04:05 PM
cc1999
Utility ATVs
36
Sep 20, 2005 08:02 PM
KMDuner
Jan 16, 2003 06:18 PM
