2006 efi 500 h/o starter issues
Power washed my friends bike with it running with seat off shut bike off after a while when I was done, and now the bike wont start.
turn key on fuel pump cycles but just clicks at solinoid and a weird clicking noise down by carberator after turning the key a couple times. Any help would be great thanks.
Regards
Regards
Welcome! Tap top of the starter and recoil area while you're trying to crank. Could be the starter and bendix is just be in a bind,plus check all wiring connections from the battery to the solenoid to the starter. Best if you have an air blower to dry everything out also,especially inside connectors,etc,then seal all connections with dielectric grease to help prevent this again.. Electronics don't like water. OPT
