Ideas on how to best set my 2016 450 ho up for gncc racing
Old 02-27-2018 | 09:20 PM
Polaris450ho's Avatar
Default Ideas on how to best set my 2016 450 ho up for gncc racing
Okay, I've got a slip on exhaust on the way have a psh button start and a tether kill switch, any more suggestions?
Old 02-28-2018 | 04:59 AM
Read this if you haven't already. Especially down towards the check list and what to expect.https://gnccracing.com/pages/gncc-101 I rode one enduro years ago and thought I was gonna die,had to pull out.Maybe a little more prep and I could have finished next to last..
Old 02-28-2018 | 06:58 AM
thank you for that I took a few notes, how do I best tune my 450ho for racing.
Old 02-28-2018 | 07:53 AM
Just have it running good and serviced. IT's going to be as taxing on your body as it is on the atv so take care of it also..
Old 02-28-2018 | 08:53 AM
do you know how to lower the front suspension on the 2016 sportsmans?
Old 02-28-2018 | 08:59 AM
Why would you want to do that???
Old 02-28-2018 | 12:55 PM
greg74's Avatar
If you want to lower it, you could go with smaller tires. Perhaps get a different set of wheels with slightly smaller tires just for racing. The smaller tires would lower your ground clearance and make it sit lower. It would also make it a little quicker because of the slight change in gearing and less rotating mass and friction. You'd lose a little top end speed though.
Old 02-28-2018 | 01:00 PM
user493's Avatar
Moto Psycho
To get less clearance over obstacles?
P.S. If you get smaller diameter tires remember that you get 1/2" less ground clearance for each whole inch smaller diameter. If you want to lower it 2" your tires would have to be 4" smaller.
Old 02-28-2018 | 02:48 PM
so even if I get smaller tires it wouldn't make enough difference and by the time I get to the right size it will drag even worse.
Old 02-28-2018 | 02:53 PM
is there not a way to lower the factory struts like the back ones?
Quick Reply: Ideas on how to best set my 2016 450 ho up for gncc racing
