Ultimate Sportsman 500 Troubleshoot!
Remove the linkage arms at the shift box levers.Use vice grips on the belcrank to get into neutral. Pop the gear shift lever into neutral. Adjust linkage ends to where they fall straight into the lever holes with no pulling.Tighten the lock nuts. This may help for awhile. If it still locks in gear,worn shift box parts may need to be replaced.
SoulShifter
12-12-2004 10:47 PM
