'90 trail boss 250 4x4 clutch cover
I just picked up a 1990 trail boss 250 4x4 and the inner and outer clutch covers are wasted. Does anyone know if the inner cover 2200792 and the outer 5433542 cover will bolt up?
If these covers wont fit will any other ones fit since the ones for this old machine are discontinued
Thanks in advance, Brad.
The backing plate and updated cover(5433542) was used in over 45 different models from the early 90s' to late as 2002. You're good to go. The clutch cover itself is similar to the old 5430771 but was made of a little stiffer plastic that wouldn't sag when it got hot and hit the drive clutch or have the belt slice covers like the older ones did..
The following users liked this post:
James White (04-05-2021)
