Transmission won’t shift
Old Jun 24, 2018 | 10:31 PM
Popo15570's Avatar
Default Transmission won’t shift
I had just rebuilt my transmission on my 2015 sportsman 570. I had put all new needle bearings, new drive and reverse chains, and new tensioners in it. Before putting the case together it shifted through the gears fine. Now that I have it all hooked up I can’t shift it out of reverse. It was stuck between reverse and neutral and was able to get it in reverse but now it won’t even budge. I’m clueless and just need ideas!
Old Jun 26, 2018 | 09:07 PM
Jason Connor's Avatar
My polaris magnum wont shift right i have to literally kick it into gear so mabye you have to force it extremely hard to kick into gear if not your gears are possibly binding or you have a damaged shift fork but polaris are notorious for there shifters it may be the linkige
litlearnhardt8
Jul 27, 2009 11:59 AM
deerslayer1985
May 14, 2008 09:31 PM
VTprairie
Feb 24, 2004 08:26 AM
