2006 Polaris Sawtooth no start
Old Oct 25, 2018 | 02:58 PM
Jinxed4e's Avatar
Default 2006 Polaris Sawtooth no start
2006 Polaris Sawtooth has spark new carb, new starter. Timing is on according to flywheel and cam gear valve lash is .003 to.005 both intake and exhaust. Started a couple of times for about 3seckonds with the choke on but wouldn’t idle give it throttle and dies instantly now no start at all but has spark and gas yes I checked the idle jet clean all clean and clear new carb. Even shot gas in cylinder still no fire but has spark. Compression is good. I’m stumped any help would be appreciated thanks
Old Oct 29, 2018 | 04:45 PM
Jinxed4e's Avatar
Default New cdi now too
New cdi now and still won’t run I’m stumped. About every 8 or 9 strokes I may get 1fire if lucky. Anyone familiar with the wiring.
Old Oct 29, 2018 | 05:53 PM
94harley's Avatar
I have the wiring diagram but in our area we dont see a lot of the sawtooths around here.
Check the connections at the left handle bar switch connector.
Check the pulse coil with an ohmmeter. Black/white wire to green wire coming out if the stator. Should read 120-180 ohms.
Old Oct 30, 2018 | 11:56 AM
Jinxed4e's Avatar
Ok got it to go someone jumped out the Etc switch I disconnected the brown and white wire from the cdi and purs like a kitten.... tried the old cdi and won’t run so I’m sure it was toast from whatever they did. Now just have to find out where it is grounding out. It’s funny though how it still has spark but won’t run I guess it advances or retards it to kill it.
thanks for the help
Old Oct 30, 2018 | 12:39 PM
sr.ruedas's Avatar
The Sawtooth is the utility version of the Phoenix, and the electrical is the same, AFAIK. Look for the kill switch failure
as you said, but also there is an ignition kill signal when in reverse. Any of these wires worn thru could cause a kill signal
to get to the CDI.
Jakeballentine12
Dec 21, 2016 09:58 PM
skimask
Dec 1, 2016 10:18 AM
FATHER6
Sep 30, 2016 12:16 PM
Hondapolaris
Apr 22, 2001 12:11 AM
RippinScrambler
Mar 21, 2001 08:04 PM
