1995 magnum 425 blowing out light bulbs
Old 04-17-2019, 05:34 PM
Jdn's Avatar
Jdn
Jdn is offline
Default 1995 magnum 425 blowing out light bulbs
Yesterday, I asked about some weird stuff on my 425. Well today, I went out and pull started it. It idled fine but would quit with just a little throttle, until I turned the lights on. I revved the engine a bit and blew out both low beams, or blew a fuse (I don't know if they are fused). So I put my volt meter on the central panel, where the fan plugs into on the left side of the steering column, and got 19 volts with a quick bump of the throttle. Is this indicating a failed voltage regulator? Also, this was done with the battery disconnected. And the machine would not run without the light switch being in the high beam position, however the high beam is not currently installed.
Old 04-17-2019, 07:08 PM
Kymco 450i's Avatar
Without a battery connected, your regularor is confused and keeps putting out high voltage. May have burned out other items. All the electrical stuff is designed to work together, when you take one part away thing will happen!
Old 04-17-2019, 07:21 PM
Jdn's Avatar
Jdn
Jdn is offline
Thank you. More background, when I connect the battery it either kills the engine or causes the engine to not go over an idle. The battery is new, and shows 13 volts while isolated. I'm at a loss.
bbrett
10-01-2008 11:24 PM
yam4fitty
01-22-2007 07:18 PM
muddymagnum
09-15-2003 10:39 PM
pflueeb
09-30-1999 09:49 PM
Quick Reply: 1995 magnum 425 blowing out light bulbs
