Sportsman 500 water pump
Old Apr 12, 2020 | 06:58 PM
mopar4u's Avatar
Default Sportsman 500 water pump
Working on buddys 2010 sportsman 500 carb. Doing the waterpump because mechanical seal is leaking at weep hole and machine is overheating. I assume the overheat reason is because the impeller is somewhat “free wheelin”, see video link. I ruled out thermostat, had fan hot wired to run 100% of time and i cleaned out radiator fins.
I noticed its missing the aluminum washer between nut and impeller, ill get that from dealer. My question is do i need to replace the impeller? Hard to tell if inner diameter has been wore/over sized, it seemed like a nice slip fit when removing, not super sloppy. If i do need to replace the impeller does polaris offer an aluminum one, all i see is plastic ones.
twlamkin
31
Mar 25, 2017 03:12 PM
BdweiserRacing8
Nov 15, 2009 09:32 AM
zeususa50
Oct 28, 2007 05:18 PM
buffdaddy
Oct 27, 2007 10:30 PM
Spears
Nov 12, 2005 12:06 AM
