Polaris scrambler 50 starting problem
I have a 2003 polaris scrambler 50 which for some reason cannot get to run. When the key is in the off position And I press the brakes it will start with kick start (why with the key in off position don't know why), it idles fine, once I release the brake it dies. Now with the key in on position it wont start either with kick or button. I press the brakes and the light comes on, it also turns with push button but won't go. I have spark and the carb is clean. I don't know if that might be the relay starter problem as it is one of those cheap ones from amazon. It just baffles me how I can get it running with kick start with the key in off position. Any ideas?
