2006 Sportsman 800 Twin EFI - stutter, hesitate, surge
Hello everyone - new to this forum, but have been a lurker for awhile, researching the issues on a 2006 Sportsman 800 Twin EFI and looking for some additional guidance as I am stuck....
Background: 800 twin has only 1200 miles, picked up used. Have two other sportsman 500's which we use daily on the ranch, one with 7K+ and the other w/10K miles. They get full fluids change out every winter and other scheduled maintenance (plugs, wires, brake/boot inspections etc.).
As I did not know the maintenance background on the 800 twin EFI, I changed all fluids per usual, but was still running "rough", rich on the fuel side (exhaust), poor to no idle, but when I gave it full throttle it has full power, no stuttering, surging etc.. Checked codes and 41/45 came up, Replaced the TBap sensor and wiring harness and cleared the codes. Ran better, but still not where should be.
Previous owner changed the spark plugs/fuel filter due to rough running. I removed the spark plugs, set proper gap (0.035) and installed new spark plug wires as they didn't ohm consistently nor snap in place properly and also cleaned the throttle body plate, checked the boots etc. (all fine).. Also ohm'd the coil which came in @ 636 Ohms, slightly above the 560 +/-10%, Idle has settled in @ 1080, no rich smell on exhaust BUT...still hesitating/surging when constant throttle applied (power, no power, power, no power)....HOWEVER...when I give it the nuts (full throttle), she goes no problem, no backing off, no loss of power, just constant climb on power. When back off to constant throttle position, back to surge, hesitate - may settle in @ 2900-3200 RPM, but then if back off or press slightly, back to same surge. I am running 91 octane w/a can of seafoam in there, but don't believe fuel/injector problem, spark problem.
My gut says TPS (throttle position sensor) which is a dealer deal. Thoughts on this or links to how others may have solved it (other threads)?
Any assistance would be appreciated.
Thank you - SDman
Thank you - SDman
Update: purchased testing harness from Amafun (cheap $12 harness w/proper end connections) and hooked up w/out the 9V battery (Dealer testing deal). Turned key on and Red/Black lead was 0.73V, steady rise as press on throttle to 3.8V. No jumps, surges way up or down. Green/Black showed 4.99V with no change when pressing throttle. Red/Green was 4.26V, steady decrease to 1.18V. Again, no jumps, surges way up/down. The way I read section 4.16 of the Maint. manual, the TPS is reading properly and working properly.
Next steps are to dig in and read more in depth on chapter 4 in general. It's an engine - fuel, spark, air....unless something is grounding out somewhere playing havoc with the ECU/EFI.
Still stuck and open to ideas......
Thanks - SDman
Thanks - SDman
Mgeraets
04-13-2013 08:09 PM
polarisidahoatv
06-20-2007 10:54 PM
