Crazy idea for a scrambler 400 4x4.... look
Old 07-16-2001, 05:46 PM
kukerdan's Avatar
Your "new" gear ratio is already set now.
what do you mean by that?
i guess 25's in the front would be better, and since im getting new rims with the tires, if there is anything i dont like, i can switch back,
the quad would be even now, and now lower in the front, i guess the lower front is better for hill climbs, but even is better then a higher front (putting 26's up there!)
no power can be lost, since all the power is in the back, i doubt ill loose anhything in AWD mode...
ok, now that im set on 25's, unless someone can argue that,
what should i get?
i want good front tires, that will turn easy, good for hardpack, but can still grab on and hold....
i was thinking.... Jackels, Bear claws, Rawhides, Or the goodyear Trackers.........
any other sugestions?
no i dont carry a spare belt, it has a new belt on it now though, and im thinking of putting one of those goodyear belts on it eventully, they seem good,
i also want to put in a clutch kit so i get power to the ground better,
if i ever do put on a pipe, i was looking at HPD and RCR, what should i get?
i want more low low low end power, dont really need anymore mid range, but it would be better to, and i dont want to loose any acceleration or top speed, if i could gain it, all the better, any sugestions on a pipe?
Old 07-17-2001, 09:10 AM
kukerdan's Avatar
raceware
07-30-2015 06:59 AM
scram5050
07-27-2015 01:23 PM
DeFox500
07-26-2015 06:32 PM
KimSJoh
14
07-18-2015 07:20 PM
maxjung
07-13-2015 05:11 PM
Quick Reply: Crazy idea for a scrambler 400 4x4.... look
