When do you use Low Range on Sportsman?
Old Jul 29, 2001 | 09:54 AM
tealboy's Avatar
I was riding a Sportsman yesterday and put it in low range and was suprised to realize it will comfortably run 25 mph in low. I am used to low range being a high torque, low speed gear. Anyway, one of the things i remember hearing is people have trouble with belts b/c they are in high instead of low gear. If you are doing a lot of stop and go with speeds never to exceed 20-25 mph, should you stay in low to minimize wear to the belt?
Old Jul 29, 2001 | 10:38 AM
motorman's Avatar
any time that use my 400 xplorer where i am off and on the throttle a lot i use low range. this is mostly in woods riding or pulling stuff. my xplorer is also equipted with EBS which works better in low range.
Old Jul 29, 2001 | 05:59 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
The manual says to use low below 10 mph.
Old Jul 29, 2001 | 06:49 PM
500DUSE's Avatar
Weedy
I talked to the polaris tech people in june(my belt kept blowing up) and he said the manual is wrong.25mph and below for low
Old Jul 29, 2001 | 08:02 PM
tealboy's Avatar
I don't own one and have never read the manual, but understand the belt is a trouble spot. It just seems logical to use the low range if running at less than 25, maybe 20. I am on a hunting lease now and generally go 15-20 mph with lots of stop and go and it seems like the right scenario for low range (whenever i get my sportsman).
Old Jul 29, 2001 | 10:39 PM
Traildog's Avatar
I can't believe 25 mph cos at 25 my HO is screaming! When I had a 98 SP my rule was 10 mph or less. As for belts I never blew up a belt, after 2000 miles I replace it cos it was getting close to min width. My HO is lower geared so I will stay with my 10-mph guideline. Works for me.
Jmuddin284
Jan 19, 2026 07:16 AM
STLyamwar
Jul 25, 2020 04:44 AM
Nondem
Feb 22, 2020 12:20 PM
nachop
Feb 14, 2018 06:57 PM
4464
Aug 21, 2015 01:46 AM
