Rear end falls out of '01 325 Magnum at 10 hours.....
69muscle,
Thanks for relating your similiar experience. Your comments were exactly what I was after and a good example of what this forum is all about. Although I agree with the rest of you re: tightening bolts; (especially on a brand new machine) I'd still probably be wanting to know from my dealer why this isn't the first time this has happened(things have a tendency to look a little differrent when it's YOUR 5 grand on finance). Would've been a shame if he'd been ripping around a corner full bore.......
John
'00SP500
John
'00SP500
Hopefuly you realize I was kidding... I've never checked any bolts on my TBoss... but I think it is a good ideas to check what you can. I'd be a little p'd off if my new ATV fell apart in the first few hours ...
I'm going to check mine when I change the brake pads this weekend.
By the way, my neighbor has a Honda that had axle problems when it was new. Doesn't mean that Hondu's are junk, just means he had a problem when it was new.
In a case like this maybe dealer could/should go thru your quad and make sure everything else is tight.
#15
DaBoss,
I knew you were just b.s'ing around and your right; I know full well that I should've went around MY machine at least once by now with a torque wrench and never did it(did torque the head bolts as Polaris' are famous for blowing gaskets). Hope my customer's dealer does him right. Thanks for the input.
John
'00SP500
John
'00SP500
rawbdiggity
34
09-02-2015 02:16 AM
DeFox500
08-14-2015 05:59 PM
