90 Scrambler X
Old Nov 14, 2001 | 04:20 PM
bermbanger400's Avatar
well like i said alaska mine didnt weight 550 i must have a special one hmmmmm.i only had to lose about 80lbs to get to where your raptor is.
Old Nov 14, 2001 | 05:31 PM
AlaskaYFM's Avatar
My bad, I thought that you had a 4x4 Scrambler 500 (dry weight of 559lbs). A 2x4 Scrambler 400 has a dry weight of 481lbs. Still pretty heavy. So what did you do to drop over 80lbs on the machine? I think I had you confused with another poster...
Even if you machine does weight the same as my Raptor, the Polaris just isn't set up for that type of riding... I'd say it takes some nuts to jump a Polaris over 30ft.
Old Nov 14, 2001 | 06:22 PM
i removed the floorboards installed nerfs,removed shifter,replaced with a homemade one,removed cooling fan,removed starterand battery,removed oil injection,replaced front bumber with a alum. one,switched to alum. wheels,replaced handle bars with alum.,and lots of other lil stuff.
you are right the polaris is not the best jumper stock but... works now has a strut for them helps out alot and pep is reworking the fox rear shock with them mods it will acutally surpise you how much different they react to jumping.also i replaced pipe and silencer.
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
