Lift Kit for Scrambler
Old Nov 15, 2001 | 09:43 PM
500SCR's Avatar
I am presently installing a tranny from a Explorer 400 4x4 into my Scrambler 500 4x4. I am goint to run at least 25's but would like to go to 26or 27's. I would like to install a lift kit and gain about 2-3 inches. I can make a kit for the front but how would I do it for the rear? Does High Lifter make a kit for a Scrambler or can I use one for another model?
Thanks
Scott [img]i/expressions/face-icon-small-cool.gif[/img]
Old Nov 17, 2001 | 07:42 PM
ARMudder's Avatar
i think you can use a xplorer lift for the back
Old Nov 18, 2001 | 03:21 AM
800twin's Avatar
Call Bert at Berts dirt works he has a scrambler 500 with 28" mudzillas and 8" of lift,24" under the floorboards.http://www.bertsdirtworks.com
Old Nov 18, 2001 | 11:00 AM
ScramberShadow's Avatar
let me know how you make out with the larger tires...i wanted to put larger tires on my scrambler but i didnt have enough clearance between the tire and the rear of the running board. i was told the only way to put larger tires on was to remove the running boards and put pegs on.
Old Nov 18, 2001 | 11:13 AM
500SCR's Avatar
You can move the running boards forward. There are different screw holes in them to move them forward or backward. What size are you wanting to run?
Old Nov 18, 2001 | 11:30 PM
if you move the floorboard forward, then doesn the bottom of the rear and front fender move forward as well? they are attached on my bike.
Old Nov 19, 2001 | 01:22 PM
Sep1's Avatar
When you move the floorboard forward, you only move it an inch or so. The fenders will not move, the mudflaps will alow for this minor adjustment. I would not go much bigger than a 25" tire, you have to keep in mind that this is a Scrambler which may as well not have any front fenders to begin with. I put 25" on mine and let me tell you will be wearing every piece of the trail your riding on. The larger tires work great in snow and deep water crossings, because of the extra clearence. I run 25"Bearclaws on the front and 25" mudmachines on the rear and it's a great combo for winter snow-cross. The 25 are big enough and there is hardly any loss in power. The only thing that I found out is, with the increased weight and traction of the front tire it really bits into whatever you are in and combine that with the power of the Scrambler and true 4x4, you definatly get a work out when those big tires are spinning like crazy going through deep mud and snow. You will loose some stability because of the increased hight and handling will suffer a bit, that'swhy I only do this swap for winter.
Old Nov 19, 2001 | 10:17 PM
jpstercj7's Avatar
Does anyone have pics of scrambler with 25's.I have seen the one on berts site.
Old Nov 19, 2001 | 10:36 PM
500SCR's Avatar
The one on Berts has 28's on it I beleive. The last time I spoke with him he was running 31's. Hopefully when his website is finished he will have some pics of it.
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
