Plugs or tire slime?
Old Dec 29, 2001 | 01:39 PM
Farmr123's Avatar
Slime seems to be OK down to 10* or maybe a little lower. Below zero, it is stiff, and will settle to the bottom of the tire, and take a while before your wheels 'balance out'. Even then, it isn't too bad if you go slow for a little while until it gets spread out inside the tire, and don't do much high-speed driving. Also, I have found different brands of sealant stiffen at different temperatures, but couldn't tell you which would be best for cold weather.
Old Dec 30, 2001 | 12:45 AM
DaBoss's Avatar
I changed tires last spring and the slime had turned hard in one. It had only been in there about a year.
Anyone else had this happen??
Old Dec 30, 2001 | 02:33 AM
Mudrunner12646's Avatar
I HAD SLIME IN SOME ATV TIRES FOR 5 YEARS WHEN I CHANGED TIRES IT WAS STILL LIKE IT WAS
WHEN I PUT IT IN AND IT WORKED REAL WELL FOR ME
slowgsxr97
Mar 18, 2022 03:40 AM
SDR-II
Sep 29, 2015 01:06 AM
Captjay
Jul 23, 2015 12:33 PM
rcappie4
Jul 18, 2015 07:51 AM
chammerbeck
Jul 17, 2015 08:06 AM
