scrambler belt
Old Jan 23, 2002 | 12:04 PM
genekell's Avatar
how often does the belt on ascrambler 500 need to be changed?
Old Jan 23, 2002 | 08:38 PM
ftwflh's Avatar
When ever it breaks[img]i/expressions/face-icon-small-wink.gif[/img]or when you take the cover off and it has bad spots in it.
Old Jan 23, 2002 | 11:43 PM
filthyhabit's Avatar
or if it shrinks (just happened to me) and gets to tight to let the clutch spin freely in nuetral
Old Jan 24, 2002 | 07:24 AM
elroy's Avatar
Their really isn't a suggested interval for changing the belt. A new belt should measure 1.188" wide. Polaris says to replace it when it gets to 1.125" wide. You only get .063" of wear on a belt. The only way to really measure it is with a dial caliper. You should also take the belt off periodically to check for cracking. What I mean by this is if you take the belt off, bend it backwards and look at the ribbed section of the belt. In time it will begin to weather check. When you bend it backwards, look between the ribs for cracks. If it has any, it would be a good time to replace it. Also, look for burnt spots on the belt, if it has any you should replace it also.
I replace mine about twice a year. This is because of my aggressive clutch and riding style. You may be able to notice that your engine has to rev a little higher before it engages. This could also be a sign that it is getting thin.
You will be able to notice a difference when you have a new belt installed. It is really amazing just how much of a difference that .063" makes. .063" is not very much but it is a world of difference in these Polaris clutches.
Jeff Roper
Feb 1, 2022 11:48 AM
exmotocrosser
Sep 13, 2019 06:12 AM
buddieboy
Dec 9, 2016 05:50 PM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
