Lightening TB
Old Feb 9, 2002 | 02:45 PM
Blazer250's Avatar
I want to lighten up my TBlazer, but I don't want to spend money doing it. What can I just take off that wont hurt anything? I have already removed the mudflaps.
Old Feb 9, 2002 | 08:41 PM
Mike Chero's Avatar
Blazer250,
Lightening anything up (from humans to quads) will require some money. You could get rid of the starter, oil injection, steel floorboards, steel handle bars, battery (if you don't run lights) and the steel screws for the plastic (replace with aluminum pop rivets and backers). Total cost, about $100.
Old Feb 9, 2002 | 11:46 PM
Ronnnnn's Avatar
About how many pounds are shed for that 100.
Old Feb 10, 2002 | 03:36 AM
AZ400L's Avatar
Approximately 10.
Ronnn, I went through various catalogs trying to figure out how much weight I could shave off a 400, and came up with around 100LBS, at a cost of about $10 per LB, even including the free stuff like removing floorboards.
Old Feb 10, 2002 | 11:07 AM
Ronnnnn's Avatar
Jerry, have you put your bike on a scale since you got it back together?
Old Feb 10, 2002 | 08:46 PM
Blazer250's Avatar
Can I just remove the battery? I thought that it would ruin something. Or are you talking about that kit thing? And how much weight will all of these things save me?
Old Feb 11, 2002 | 03:35 PM
Blazer250's Avatar
Old Feb 11, 2002 | 04:12 PM
walexa's Avatar
I'm not into lightening my atv, but on a trailblazer, you could also replace the steel rims with aluminum ones. A full oil tank probably weighs around 4 lbs. Not sure on the battery. You can take off the sprocket protector (metal disk) as well. The flywheel can be shaved down if the starter is removed, and my stock flywheel (Xplorer 400)weighed around 6 pounds. I think advertisements boast shaving 2.3 lbs off the flywheel. This also allows the quad to rev higher. Either which way you go, it will cost $$$. What's bad is that on top of that, you're not going to see real improvements unless you lighten it up alot.
Waylan
Old Feb 11, 2002 | 08:29 PM
red400ryder's Avatar
Blazer250 I did have a trailblazer like two months ago and I was thinking about taking the trailblazer and trying to lighten it up I also took off the mudflaps but them back on. but anyways the quad caused me problems and I got rid of it and I ride now a 2001 honda 400ex which I really love. If you do want to lighten it up there is a guy on this forum I think. He has a trailblazer also and he has lighten his up and he said he shaved off it like 200lbs his name is something like "scramblerx" If I remember correctly. if you can find him he could help you out with this. hope this helps you and you find a way to fix it like you want it. later from #1 stunning madmike
Old Feb 12, 2002 | 07:29 PM
Blazer250's Avatar
Thanx for the info. I sent him a private message. His name is x_scrambler3.
jmoney45
Aug 25, 2002 09:54 PM
RC350
May 16, 2002 05:28 PM
sandfreak
Feb 3, 2002 10:14 PM
ScoobyDFW
Dec 27, 2001 09:05 PM
Keenan
Dec 5, 2001 08:28 AM
