Pulling right
Old Feb 11, 2002 | 01:04 PM
Deepcut5's Avatar
My 335 is pulling to the right. I just had the right front hub fixed with new seal and everything. What else could be causing it to pull to the right.
Old Feb 11, 2002 | 02:04 PM
GE4x4's Avatar
I had a Polaris Sport that was pulling, it was due to not having the same amount of air as the other tire. After that it was fine. Another thing to look at is the toe out and make sure both tires are the same. One more thing, tie rod ends, too much play on one side will pull.
Old Feb 11, 2002 | 04:15 PM
BUBASCRAMBLER's Avatar
I had the same problem on a 01 Trailblazer, and it was also the REAR air presure that was not set the same (I even put a Hot Seat Lower Steering support). (Never thought of AIR presure at the time, Daaaaaaaaa)
Hope this helps
Valder
Nov 28, 2020 07:38 AM
fordfaithful21
Dec 7, 2015 05:52 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
black798
Sep 9, 2015 07:42 AM
awer1968
Sep 8, 2015 11:02 AM
