polaris engine
Old Feb 20, 2000 | 09:17 PM
clemi's Avatar
I AM HAVING A LITTLE PROBLEM, IF I PUT MY BIKE IN NEUTRAL IT IS HARD TO PUSH. I TOOK OFF THE CHAIN AND I CAN'T TURN THE COUNTER SPROCKET WITH ONE HAND, I ALSO REMOVED THE BELT FROM THE OTHER SIDE OF THE ENGINE AND THE SPROCKET IS STILL HARD TO TURN, IS THIS NORMAL OR WHAT? BY THE WAY I HAVE A 400L ENGINE. THANKS PLEASE REPLY. MY BIKE IS 97 400 SPORT THAT HAS BEEN SLIGHTLY MODIFIED.
Old Feb 20, 2000 | 10:39 PM
mudmachine's Avatar
OK.... first... is it a 4x4? what year? Model? Modifications?
This information would help with diagnostics...
Old Feb 21, 2000 | 01:05 AM
clemi's Avatar
THE BIKE IS FOR MY FATHER INLAW AND IT IS A 97/98 I AM NOT PERFECTLY SURE 400 SPORT THAT IS MODIFIED
Old Feb 21, 2000 | 01:32 AM
clemi's Avatar
MUD MACHINE CAN YOU GIVE ME AN E-MAIL ADDRESS SO I CAN SEND YOU ALL THE SPECS?
Old Feb 21, 2000 | 09:32 AM
97TrailBlazer's Avatar
why don't you just post them here, so everyone can see what's wrong. I'm interested in knowing now!
Old Feb 21, 2000 | 10:06 PM
mudmachine's Avatar
clemi,
Ok.. first things.... Are we sure the bike is neutral since you took the chain off? When is the last time that the transmission oil was changed? There is some "drag" caused by the transmission that is normal... How is the bearing/bushing on the output shaft? greased it lately? Has the machine been greased lately? Check the tire inflation pressure and equalize... Hows the front end alignment? Since you have the clutch cover off, the driven pully DOES turn freely? Check your brakes and make sure you don't have them adjusted to tight...
You said you couldn't roll it easily, then you said you took the chain off and the sprocket was hard to turn, Did you try to push the quad now that the chain is off?
Check these things and rule these out first....
Old Feb 23, 2000 | 12:35 PM
clemi's Avatar
THE COUNTER BALANCE SPROCKET HAD THE BEARING BINDING SO THAT IS WHAT ENDED UP TO BE THE PROBLEM. THANKS FOR THE INFO
MikeyBoyesq
Nov 27, 2020 02:44 PM
neilbedwell
Nov 10, 2018 11:02 AM
Thanos
Jul 12, 2015 08:40 PM
TJM
Jun 11, 2015 01:28 PM
wildbill59
May 28, 2015 12:05 PM
