Counter Balencer Fluid???????
Today while riding my Scrambler 400L I noticed some oil on the frame in front of the engine , below where the pipe goes to the cylinder.Upon looking closer I seen that a threaded plug was missing from a hole ( right beside where the oil injector was). I stopped riding immediatly because I know that I had been in some deep water and was afriad water had contaminated the oil.What is this and what type oil goes here?I also found on the bottom of the engine right below the pull start what looked to be a drain plug for the same reservoir.I removed the plug and nothing came out...not even water. Is this how you drain that reservoir? Luckily I found the missing plug still on the frame trapped in a hole it could not fit through ( lucky ) . I just had this engine rebuilt and figure it was not tightened properly.OK guys tell me what I need to do!!![img]i/expressions/face-icon-small-smile.gif[/img]
Thanks,
J. Prentice
