Brake noise question.500 Sportsman.
#21
Keep in mind boys, the roter on the 96 floats, this proved to be a very poor design. I think in 99 they went to the floating caliper like most cars / trucks run. I fixed mind by installing a thick o-ring from any fuel injector (I used ones from a dodge caraven) on the inside and outside of every other roater stud. the roater can still flex to allow the float, you just need to look at the ajustment more often to keep the tolorence correct. Works great.
#22
Dc, My uncle and I go about every week to around Kinta and Lequire. It is about an hour south of Muskogee. There are over 13,000 acres of trails in the mountains. Excellent riding. This past Friday, we had to make our own trail down a mountain because the one we were on ended and we didnt want to go back up it. We carry a chainsaw and handsaws. I am still sore from all the work.
#24
It's my opinion that they all can make noise(floating type)this is one of reasone Polaris updated the rear system. My advice to you is that if your pads are in good shape and the roater has not been damaged, the noise is more of a nucence and a cause for slight premature pad wear that anything. Keep in mind when making ajustments to the rear caliper (fixed) that the roater can be moved in and out on the tappered shaft to acomadate any mods you may have done or choose to do, such as the o-ring trick I talked about in the preveious thread.
(Keep the go button pinned and you won't hear the noise)
#26
Well thanks to your help guys I got my answer, got a friend to pull it backwards while I reached in and got a couple fingers on the rotor and sure enough when it made the noise it was the rotor chattering from side to side, very slight movement but lots of noise. Thanks again guys.[img]i/expressions/face-icon-small-happy.gif[/img]
#27
