Oil Injection after complete rebuild
It should, just follow the bleeding procedure in the owner's manual.
Also, I think it is a good idea to run premix on the first tank or two of fuel anyway. The extra oil may or may not foul a plug or two (less likely with synthetic oil) but at least you will be assured of lubrication in case a bubble of air that you didn't see goes through.
