Warn 2500 vs. 2000 ?
Old Apr 6, 2002 | 08:40 AM
mud2myeyes's Avatar
The only problem I have with the Warn "A" and "U" winches is the plastic geared end housing that tends to strip out under extreme load. After replacing a few end housings (about $40 each), I went to an all metal Ramsey 2500. I built a mount using the 2" receiver system, and I can move it easily from front of my SP500 to the back, also put a receiver on my trailers and the bed of my truck to winch in stuff like dead cars, quads, and riding mowers - instead of straining a gut trying to push.
Old Apr 6, 2002 | 09:04 AM
mtpockets's Avatar
BILLYclub,
i looked it up, the Ramsey atv2500 makes the cool wireless remote. i want the versatility of a multi-mount to. i wonder if they offer it...Warn does.
see-ya,
MT
Old Apr 6, 2002 | 10:44 AM
soupcan's Avatar
Keep in mind that a atv simply will not produce enough power to be able to use a winch to its full capacity. Whether or not the 2500 with its oversized solonoid and wiring enables more efficiency of the power supplied to the winch by the atv is probably realistic. So I would have to say the 2500 would be a better puller than the 2000. In this case its still unlikely the 2500 is being used to its fullest with a quad vs a pick-up truck. But for four wheeling its plenty. There are countless war stories out there on how our winches have saved our a$$es. Once you have one, whether a 2000 or 2500, you will be glad you do.
Another thing, the amps produced by quads will vary depending on the make and model of the machine. More amps, more power to the winch. This is why some guys winches' will bog down and barly pull them out. And his buddy with the same winch seems to pull much better. Have fun
Old Apr 6, 2002 | 10:56 AM
KellerSP700's Avatar
I've just recently ordered the Warn 2500lb winch for my SPortsman 700. It is supposed to be in this week sometime. Has anyone put one one themselves? If so, how hard was it?
Old Apr 6, 2002 | 11:24 AM
  #15
Billyclub's Avatar
Excellent posts, thanks for the useful info. I will look into the Ramsey as well as the Warn 2500. Any place you know of that rolls in the cost of the mount with the winch and sells them as a complete package?
Old Apr 6, 2002 | 12:08 PM
  #16
hausdog's Avatar
Some info that may help.
http://www.askgeeves.com/main/metaAn...t=020406080126
Jeff Roper
Feb 1, 2022 11:48 AM
Gwolf228
Feb 18, 2017 01:36 AM
Dammar
Apr 20, 2016 06:03 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
panicmanic
Sep 28, 2015 12:59 PM
