cv joint clamps
Old Feb 29, 2000 | 06:58 PM
bigred85's Avatar
Hi there, does anybody know if there are special pliers available to install the cv-joint boot clamps on Polaris ATV's.
Old Feb 29, 2000 | 07:13 PM
dusty's Avatar
Yes there is! I believe I saw them in the Dennis Kirk catalog, for a measly $85
I think for that price I'd get a $.50 hose clamp.
Brian
Old Mar 1, 2000 | 12:08 AM
SportsmanDave's Avatar
You can't use a hose clamp 'cause it will hit the strut housing. I used a heavy pair of needle nosed pliers, they worked great! Thats what my dealer recommended.The clamp has two lugs sticking up, grasp each one and pull the clamp tight enough to hook the tabs. It looks harder than it is!
Old Mar 1, 2000 | 01:21 AM
monster500's Avatar
I went to walmart and paid 10 dollars for a pair of fencing pliers and they are it! I Tried every thing else and with this thing I put it on in a matter of seconds with very little strain. They are the perfect tool.
Old Mar 1, 2000 | 06:33 PM
truck's Avatar
SNAPON SELLS THESE CV BOOT PLIERS PART #YA3080
FOR $27.85 THESE ARE THE SAME ONES POLARIS SELLS FOR $85.00
TRUCK
Old Mar 1, 2000 | 09:10 PM
Todd Irvin's Avatar
Auto Zone sells a cv boot clamp tool for @ 5, but a pair of small ChannelLock pliers worked for me...I made a special trip to town for the tool, and didn't use it. I like the idea of the fencing tool, too. Just be sure to get a good grip on the little tabs and don't bugger it up too much or you'll be cussin' all the way back to the Polaris shop for another one.
Also, IF you can get the old ones to come off w/o cutting, you can reuse them...but let me warn you, this won't work if you're counting on it...go ahead and buy them and try reusing the old ones...they seem to know if you're under pressure......
Old Mar 2, 2000 | 07:09 PM
bigred85's Avatar
What are fencing pliers and what do they look like? Does it matter which brand?
Old Mar 2, 2000 | 11:18 PM
toyman's Avatar
I used a pair of snap-on battery terminal pliars, the points are bent a bit and they fit right into the points that stick up on the clamp, work great first try.
STLyamwar
Jul 25, 2020 04:44 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
89Lt250r
Sep 7, 2015 07:53 PM
toonces
Aug 13, 2015 12:40 PM
