My Sportsman 335 cuts out @ 1/2 throttle. I've disconnected rev. override, drained gas, ...
Old May 13, 2002 | 07:46 PM
SuperDuty335's Avatar
Like I said, I've drained the gas, checked the plug,exhaust,air filter,I've disconnected the reverse override, and it still won't even climb a small hill without cutting out and I've got a trip planned this Friday for Hatfield & Mccoy!!! Help!?!
Old May 13, 2002 | 08:34 PM
hodaddy's Avatar
ii have a friend with a 335 his started doing the same thing and it ended up being the choke was stuck. my 2000 sportsman 500 started cutting out at about 1/2 throttle and mine got progressively worse and it ended up being the cam. i know quite a few people on the 500 and 500 ho that have had cam problems. the exhaust lob wears off. some of the guys i know had less than 500 miles on the bikes. you can pull the top part of the head or take the valve cover off and roll the engine over and you can see if the exhaust valves are opening all the way
Old May 13, 2002 | 10:47 PM
I fixed the problem! My intake snorkel was getting sucked against the gas tank and shutting off my air supply. I trimmed a lot off the snorkel and it runs like new again. [img]i/expressions/face-icon-small-happy.gif[/img]
Old May 13, 2002 | 11:30 PM
Quadmaster325's Avatar
try draining the carb and run some dry gas in u gas tank. mine bike was doing the same and thats what i did and worked. good luck hope his helps
Old May 16, 2002 | 12:09 AM
ftwflh's Avatar
Last resort try adjusting your valves and while your at it look at the cam.
Old May 20, 2002 | 11:32 PM
clean out the carb. urneedle valves coud be screwd up. there also could be something wrong with the float bowl . u might be sucking air some where. let me know how u make out
Old May 22, 2002 | 12:06 AM
Maniac7599's Avatar
Buy a Honda!
skinnyr6
Aug 25, 2023 02:18 AM
GregM
Mar 6, 2018 06:53 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
