starter problems
Old Aug 13, 2002 | 04:51 PM
cwdancer's Avatar
I have a 2001 HO and when I hit the starter button the starter doesn't always engage.I was going to pull off the recoil cover and check out the starter and bendix spring.Anybody with the same problem?
Do I need a new gasket for the recoil housing when I re-assemble it.
jimmy
Old Aug 13, 2002 | 07:06 PM
xcrider's Avatar
Try jumping the battery and see if it starts then. You should measure your voltage with no drain and with the starter button engaged.
Old Aug 13, 2002 | 07:10 PM
ftwflh's Avatar
Clean all your conections on the batrry and the starter relay.If that dont work jump around the relay before tearing into the starter.
skinnyr6
Aug 25, 2023 02:18 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
tweeder
Jul 5, 2015 01:57 PM
