Trailblazer cuts out when jumping
Old Aug 26, 2002 | 05:10 PM
Polarisdude's Avatar
Anybody else have this problem? My '00 Blazer cuts off momentarily when landing from jumps, what causes this? Can it be cured?
Thanks,
PD
Old Aug 26, 2002 | 06:22 PM
talonhawk's Avatar
I think its a carb problem and yes, my brothers 400 sport
does the same thing sometimes!
Old Aug 26, 2002 | 07:03 PM
TINKERMAN's Avatar
What year is your trailblazer?
I had a 400 sport that did the same thing.
I bought a rubber piece that mounted to the top of my transmission just under the carb.It would not let the carb. jump around.
It took care of my the problem.
Dealership said that jumping made the gas in the bowl of the carb get air bubbles.
Old Aug 26, 2002 | 07:25 PM
scramblered's Avatar
it is probably the carb shaking/twisting too more faoming bad the mixture into the motor,are you running with
no airbox? if so a patented bracket to hold tight the carb will help,
but if you still pull the trigger when landing the jumps it can cauze the engine to bog as the clutch system is getting a hard time to spin.
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Bernhard
Sep 25, 2015 12:45 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
black_thunder
Sep 22, 2015 07:59 PM
