sc500 clutch slipping
Old Sep 11, 2002 | 09:58 AM
riderrideshard's Avatar
my clutch will not hook up even in the mud. if i put on a new belt the clutch works great for a while then it will not even pull the front wheels up .i have checked the aligment to andit was fine. i even tried the hpd belt and all it did was put grooves in my primary.also i noticed that when i trail ride in the woods my clutch cover gets very hot. [img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Sep 11, 2002 | 06:10 PM
buffalosoldier's Avatar
I think I might have a similar problem. I used to be able to wheelie my Scrammy (*when it was low on fuel...less weight) by just goosing the throttle. Now I can't ever do that. I've noticed my clutch cover running hot too, so I'm going to pull off the clutch cover and wipe down everything with brake cleaner. If the belt isn't looking great when I take the cover off I might switch over to the 700 belt -- my machine is still on her first belt anyway, so I wouldn't mind having the extra "peace of mind" that I'm running a fresh belt.
Old Sep 11, 2002 | 06:30 PM
Bubba297's Avatar
I think I would call Mike at HPD between 3-5 central and hit him up for some info. Their clutch kits work great.Did you buy the agressive clutch kit? Do the belts appear to have a burned look on the sides? There has to be some excessive slippage somewhere to be causing your problem it sounds to me. I hope you can figure it out.Bubba
Old Sep 11, 2002 | 06:32 PM
xcrider's Avatar
If your primary has grooves in it it is probably shot. The face should be smooth from the center to the outside of the face
Old Sep 11, 2002 | 06:37 PM
PolarisMech's Avatar
if your cover is running really hot you might wanna pull the secondary apart, and check for wear or damage.
Old Sep 11, 2002 | 06:47 PM
shagdog19's Avatar
i had the same problem with my 2000 scrambler.i put a dg pipe on it and the clutch would not engage at low rpms.i then tried a stiffer clutch spring (green) and it works exellent.as for being in mud the belt will slip when it gets wet.then you have to llift the back end up and goose on the throttle untol it dries.you can try that hope it helps.
Old Sep 15, 2002 | 01:59 AM
2002scrambler's Avatar
i had the same problem with my clutch slipping i burned up my belt in mine so i went to the white spring in my clutch and went with the 700 sportmans belt it helps on low med and top end
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
jbrewster94
Sep 23, 2015 04:16 PM
