Grease Fittings?
Old Nov 13, 2002 | 08:29 PM
highwayman's Avatar
Default Grease Fittings?
I recently bought a 99 335 Sportsman and like it very much for trail riding and hunting. But I am wondering how to grease the front and rear wheel bearings. Are there zircs? (grease nipples) or do they have to be hand greased like a car and if they are like a car are there seals to replace every time? I find it hard to believe that Polaris would put sealed bearings in considering how much greasing is done every where else. I do not mind greasing and probably over grease everything except the prop shaft yoke, tend to go through a lot of water holes.
This forum is great and usually check it out every night.
Thanx in advance
1999 335 sportsman
Stock for now
Next year 4x4 magnum for wife
Old Nov 15, 2002 | 01:34 AM
Traildog's Avatar
I believe the 335 is the same setup as the 500 so here goes. The rear bearings are a double wide (not sure of the correct term) sealed bearing and require no greasing. Be prepared to replace them after a few years of service as they don't keep the mud out forever. At the front end the bearings are inside the front hub assembly. The inboard side is protected by a cup seal and the outside by the black cap with an O ring seal and 3 allen screws. No greasing is required because the hub is 1/3 filled with Polaris's front hub fluid.
Hope this answers your question.
Old Nov 15, 2002 | 06:42 PM
highwayman's Avatar
Thanks for the info Traildog. I tried my buddies 500 ho and it worked real good. ALMOST wished I kicked out another 5000 for a 500. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 16, 2002 | 02:01 AM
Traildog's Avatar
These units are pretty heavy so I think a 335 would be a little under powered compared to the 500. Having never ridden one I am making assumptions but the lack of power and the smaller tires wouldn't cut it for me.
Old Nov 16, 2002 | 03:56 PM
Elbongo's Avatar
Traildog, you are right. I own a 00 SP335 and it weighs 670 lbs. That is the dry weight. It needs a bigger engine.
EIF
Apr 20, 2017 07:15 PM
tysonbully
Sep 28, 2015 02:30 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
bigred20653
Sep 19, 2015 02:11 PM
bmark0610
Sep 7, 2015 09:42 PM
